82custom Posted April 5, 2009 Report Share Posted April 5, 2009 hello my name is mike new to this site hopefully i can find someone who might be able to help me out. found a webber carb the other day at local salvage yard looked in good shape picked it up for 25$ numbers are 32/36 DGAV 33b1 trying to find online converision kit for my engine but most i have found come with a carb which i dont need. am planning on getting the jets replaced if need be to the ones specked for the z if anyone can help would greatly appreciate. thnx mike Quote Link to comment
banzai510(hainz) Posted April 5, 2009 Report Share Posted April 5, 2009 webercarbsdirect.com piercemanifolds Top End performance Quote Link to comment
Guest nateoneel Posted April 5, 2009 Report Share Posted April 5, 2009 (edited) even better yet, i saw two weber carb adapters at the junk yard in lagrande or. i go down there twice a week so i can pick one up for you. i'll write back once i get it.:D wait i don't know if it will work in a Z mani, it will be coming off a L20b motor. Can any one answer the question? will a carb adapter from a L motor work with a Z motor? Edited April 5, 2009 by nateoneel Quote Link to comment
datzenmike Posted April 5, 2009 Report Share Posted April 5, 2009 The carb mounting studs are spaced differently on the Z24 manifold than the Z22 and under motors. They are wider along the length of the carb. The studs are spaced 3 3/16" X 1 3/4" or 80.9625mm X 44.45mm. The Weber 'might' bolt right on to the Z24, you should check. Quote Link to comment
datto510 Posted April 7, 2009 Report Share Posted April 7, 2009 http://seattle.craigslist.org/kit/pts/1110717725.html Quote Link to comment
