Moisabamf Posted April 2, 2009 Report Share Posted April 2, 2009 what is the process? do i remove leafs first, or the gas shock first:confused::confused::confused: answers please, i want to see if i can get this done today Quote Link to comment
DRIVEN Posted April 2, 2009 Report Share Posted April 2, 2009 If you are just replacing the axle assembly (rearend), you probably don't need to pull the springs. In this order: driveline, tires, E-brake cable, shocks, U-bolts and shock mounts, brake line. Then slide the axle to one side or the other. Good luck. Quote Link to comment
Moisabamf Posted April 2, 2009 Author Report Share Posted April 2, 2009 i am replacing the springs too. so to i just add springs to the mix and drop it down? Quote Link to comment
DRIVEN Posted April 2, 2009 Report Share Posted April 2, 2009 Pretty much. There really aren't any surprises involved. The spring shackles are can be tricky just because they have been together for 35 years. Use plenty of WD40 and be careful with the threads. You shouldn't have any trouble with this job. It's pretty straight-forward. Quote Link to comment
Moisabamf Posted April 2, 2009 Author Report Share Posted April 2, 2009 alrighty, thanks alot, but now it turns out our floor jack is busted:p Quote Link to comment
420n620 Posted April 2, 2009 Report Share Posted April 2, 2009 turns out our floor jack is busted:p was this from the bust next door to you yesterday, your jack needs to find better friends. :lol: sorry to hear the bad newz.... Quote Link to comment
