what cam?
haubstr
I have an L20B bored 30 over, an A87 peanut head shaved and ported, with dual solex 40's. I want a performance cam but not to wild. this isnt my daily driver but i'd like to take it to meets and to work sometimes.
anybody got suggestions on a cam?????
  • Replies 6
webcamshafts.com
Schneider
Isky
Colt and Shadebolt out of Canada
and maybe a few other brands out there
Bigger cams over about .475 lift should get new Bigger springs.
all will need new Rocker arms/Resurfaced
lash pads of bigger size and retainers.
allsaid and done add 500$ to 800bucks. More if other added things.
matchport intake and manifold if you have the bigger intake runniers. ect
why i'm asking is because i was trying to run my truck with the stock cam and it runs like crap. i know the carbs are out of adjustment but what will the effect be if the carbs are in adjustment but the cam is stock.
I would put a weber DGV on there and see how it runs.
If good your cam is not bad but your carbs can be out of sync or just not jetted right or just junk.
ck timmeing again
Maybe adv it to 12-15DTDC with a light
I have a pair of 40mm mikini solex and they worked fine with stock motor and with a cammed ported motor(no jetting) maybe I got lucky.
also open up the top of the carb and cheack to make sure the jet blocks are tite
also ck to make sure the inner airhornsa(venturis are not loose) mine come loose every now and then
Edited by banzai510(hainz)
