The axle is strong enough. That's for sure. The AMC 20 has a pretty good aftermarket product base that the Datsun axle doesn't have. Also the ring gear is stronger than a dana 44. If something has a good possibility of failing I like to replace it with something that I can get good aftermarket support for. Also, as stupid as it sounds, I like the ability to lock the rear diff for whatever reason (snow,ice,maybe launching on less than favorable surfaces). The datsun axle is great, but I would rather replace it with a part with better aftermarket support. Also, the AMC 20 is cheap. Like 50 dollars if you know where to look. I'm going to put disc brakes on it and its easier to find parts.
The boosted Z22 isn't built yet so I don't know what kind of hp it will make. I going with a heavy cam, turbo making 16 pounds of boost, forged pistons, twin webers, fender exhaust, shaved head, and O- ringed block. That will give me a little bit of pepper. 🙂
