Hey I just did a dizzy swap to get rid of my dual point distributor I bought the hot spark dizzy with the coil for 130$.It was a easy swap only 2 wires to reconnect and a slight mod to the timing plate . It already runs much smoother now and I haven’t even put a timing light on if yet
No the spindle is shot because of a bent support on the passenger side plus their was no way to grease anything everything had a small plug where the grease fittings shyness I’ve rebuilt the whole front end except for the spindle and fulcrum
Hey guys I have a question I’m hoping someone can answer I’m looking at buying a upper link kit off of eBay but it say it’s for a 620 part number 54536-b0125 I’m wanting to know if this should work on my 521 the first 5 numbers match up
Yeah you’re right I pulled the distributor earlier and it had two condensers one was hiding and one was larger than the other.when I pulled the distributor I was expecting it to have a gear on the bottom
