I did just that Z-train thanks. I read up on all the tank problems....and sure enough the tank was nasty! I had to do the acid wash a few times but it's clean now and has a filter before the pump. ;)
I just picked this little gem up for a steal at 500$ I'm planning on just cleaning it up a bit and using as a daily so I can actually start working on my dime again.....
It runs good and has working a/c!
I will post more pics later....
Hey Eric!
I am using z struts and calipers in the front and for now still stock drums in the rear. all the hardware is new. And I am running a close ratio 5 speed from a 200sx
Finally some new pics and an update! I primed the body today after doing a bunch of work on the quarters for the last several weeks in between work.
I am blasting the door insides then final sanding and sealing them then painting them and my hinges
We took it for it's maiden voyage up the street yesterday. It still needs some suspension work. I put in new adj tc rods and the proper center link but the strut inserts are shot to the point of being noisey.
