guam_napz Posted March 1, 2009 Report Share Posted March 1, 2009 Will the 300zx trans bolt up to a 720 with a bell housing swap and also the driveshaft. Quote Link to comment
yellowdatsun Posted March 1, 2009 Report Share Posted March 1, 2009 The Z31 300ZX transmission is one piece, no separate bellhousing. Quote Link to comment
datzenmike Posted March 1, 2009 Report Share Posted March 1, 2009 (edited) Actually I think you might be able to. The Z31 came with three different manual 5 speed transmissions. All manual non-turbos used a 5 speed Nissan transmission (FS5W71C) which is quite reliable. The 84-86 manual turbos used a Borg-Warner T-5 5 speed (FS5R90A) which is not very reliable. The 87-89 manual turbos are internally, the same as the nissan transmission found in z32 turbos, trucks, pathfinders, etc (FS5R30A) It is the ultimate in tough. The FS5W71C from a Z-31 is internally the same as that from a 240sx and will easily fit the front half of the case from an '84-'86.5 Z24 tranny. (earlier Z22/Z24 trannys will need some mods. the same mods should allow even an L 'bell' to fit) This is a tough tranny, and those with turbos that blew up their newer T-5s, have replaced them with the FS5W71C and found it will easily handle the turbo... and more. http://i138.photobucket.com/albums/q251/datzenmike/Tranny/transFS5W71Cnonturbo84-88Z31-1.jpg[/img]"] Edited March 1, 2009 by datzenmike Quote Link to comment
yellowdatsun Posted March 1, 2009 Report Share Posted March 1, 2009 The Borg warner T-5 was only available in 82'-83', and never available in the 300ZX. I now have one in my 81' Turbo. The BW T-5 was only available for those 2 years. It also looks *VERY* different than the Nissan boxes. The 300ZX unit looks like the one in the pic, and looks the same as all other Nissan manual transmissions. The T-5 is a big square box looking thing, with a normal American style detachable bellhousing. The discrepencies come with the fact that Nissan copied the shifter mounting plate, so from inside the car the 300ZX manual "looks" like a T-5. Quote Link to comment
datzenmike Posted March 1, 2009 Report Share Posted March 1, 2009 (edited) Also known as the FS5R90A with VG 'bell' on it, and used from '84-'86. : Here is your T-5 with L bell on the right. http://i138.photobucket.com/albums/q251/datzenmike/Tranny/BorgWarner4-1.jpg[/img]"] Edited March 1, 2009 by datzenmike Quote Link to comment
yellowdatsun Posted March 1, 2009 Report Share Posted March 1, 2009 Ahh, my bad. Everything I ever read said that they were only used for 82'83. That's definitely a T-5 though, you can see the big square center section. I stand corrected. Quote Link to comment
datzenmike Posted March 1, 2009 Report Share Posted March 1, 2009 (edited) I'm guessing it's the same but with a VG bell. I don't think it can stand up to VG power. The '82-'83 is called a T-5 but '84-'86 isn't, instead it's listed as the FS5R90A. The FS5W71C came out around '86.5 because of the VG and near future KA motors that were coming along. The T-5 was 'adequate' for the L28 and it's best feature was that it was cheap and easy to re-build. Putting the L bell on front of an FS5W71C was a much better solution. Edited March 1, 2009 by datzenmike Quote Link to comment
