PtheDude Posted January 25, 2009 Report Share Posted January 25, 2009 I spent 20 minutes searching. I'm looking for offset info, and hell, even a list of link for direct bolt 16"-17" rims would be great. 02-04 Xtera, right? Quote Link to comment
PtheDude Posted January 25, 2009 Author Report Share Posted January 25, 2009 http://seattle.craigslist.org/est/pts/998388724.html Quote Link to comment
lynchfourtwenty Posted January 25, 2009 Report Share Posted January 25, 2009 (edited) 6 x 5.5 no those wont fit.. jk Edited January 25, 2009 by lynchfourtwenty Quote Link to comment
lynchfourtwenty Posted January 25, 2009 Report Share Posted January 25, 2009 oh but i had to use some of these spacers cause of my wide tires, some people with smaller tires may get away with out it tho Quote Link to comment
PtheDude Posted January 25, 2009 Author Report Share Posted January 25, 2009 http://seattle.craigslist.org/est/pts/1006286922.html do the chevy 6 lug/holes fit? How wide can a guy go before I rub, with standard suspension settings? just swap out the 14's and go? Quote Link to comment
lynchfourtwenty Posted January 26, 2009 Report Share Posted January 26, 2009 those look like they will fit... i have all stock suspension an crap but like i said with the tires i have i had to use those big adapters.. Quote Link to comment
Jester Posted January 26, 2009 Report Share Posted January 26, 2009 The biggest problem with mounting wheels from a new rig is the center hole in the wheel. The newer ones are too small to fit over our hubs. That is why people go with the spacers or maching out the wheel. You can also have the hub machined to take away the little "ribs" on the center of you stock hubs. The wheels in your last post should bolt right up. Quote Link to comment
ariascarlos1990 Posted January 26, 2009 Report Share Posted January 26, 2009 The biggest problem with mounting wheels from a new rig is the center hole in the wheel. The newer ones are too small to fit over our hubs. That is why people go with the spacers or maching out the wheel. You can also have the hub machined to take away the little "ribs" on the center of you stock hubs. The wheels in your last post should bolt right up. no need to get the "ribs" machined. take the grinder to them its work the same and its cheaper. :D Quote Link to comment
