UNCIVLIZED1 Posted January 23, 2009 Report Share Posted January 23, 2009 So after trading off my 521 a couple of months ago, I just bought it back and it needs a little work. The truck was stuck in 4th gear when I traded it and th eguy never even came and picked up the truck so it is still in the same condition. I located a transmission for it through a guy locally and will be picking it up this weekend. I want to go ahead and change the clutch, slave cylinder and master cylinder while I am at it since they werent always workign properly when the truck was driving (hence the tranny problem). I called a few local parts stores and havent come up with anything. Would RockAuto.com be the best place to look for them? Are they pretty quick with their shipping and accurate with stocking the parts they list on their site? Quote Link to comment
sdsurf Posted January 23, 2009 Report Share Posted January 23, 2009 They are a very good source for all of that. I bought a clutch kit from them but I had to buy it for a 510 (wasn't listed for 521). Worked out great... So after trading off my 521 a couple of months ago, I just bought it back and it needs a little work. The truck was stuck in 4th gear when I traded it and th eguy never even came and picked up the truck so it is still in the same condition. I located a transmission for it through a guy locally and will be picking it up this weekend. I want to go ahead and change the clutch, slave cylinder and master cylinder while I am at it since they werent always workign properly when the truck was driving (hence the tranny problem). I called a few local parts stores and havent come up with anything. Would RockAuto.com be the best place to look for them? Are they pretty quick with their shipping and accurate with stocking the parts they list on their site? Quote Link to comment
UNCIVLIZED1 Posted January 23, 2009 Author Report Share Posted January 23, 2009 They are a very good source for all of that. I bought a clutch kit from them but I had to buy it for a 510 (wasn't listed for 521). Worked out great... There is a listing on their site now for a clutch kit for a 521 from ACDelco....should this be the right one? Quote Link to comment
slodat Posted January 23, 2009 Report Share Posted January 23, 2009 I really like Rock Auto. No problems. I've bought a lot of their closeout specials in the past year. Quote Link to comment
banzai510(hainz) Posted January 23, 2009 Report Share Posted January 23, 2009 (edited) I just bought a clutch kit from these guys all made in Japan stuff even T/O bearing(KOYO) but its a stock clutch No burn outs with this one http://www.importrp.com/product.php?productid=61784&cat=0&page=1 I have to pull out my Centerforce clutch Cause something is wrong with it in my 521. Since its cold Im going to wait until spring and drive the 510. Let me know how you do this clutch change as last time I did mine I put a new motor in there and swap the clutch then. But Never pulled from bottem. 510er said he did his from the bottom(PM him). He said pull the motor back then turn 90 degs and drop the front down and pull out. Truck has to be hIGH off the ground. Edited January 23, 2009 by banzai510(hainz) Quote Link to comment
