tyson Posted January 6, 2009 Report Share Posted January 6, 2009 I just recently picked up a 66 520 and I want to do some updated brakes on it cause as of now it has a bad master cylinder and needs some attention to the brakes anyway. Before I go out and spend a bunch of money on the wrong parts I wanted to ask you guys what would be the best result at a reasonable price. I want to convert to power brakes and discs all the way around. Will I still be able to run my 14" steelies with whitewalls? Quote Link to comment
datzenmike Posted January 6, 2009 Report Share Posted January 6, 2009 You probably have a single m/c, so it would be a really good idea to up-grade to a dual. This will separate the front wheels from the back and will alow one set to work even if there is a failure in the others. The 620 has this and also a booster, a similar one is on the B-210. I don't remember if the 521s had the booster but all the 620s did with a 3/4" master through '77. '78 and '79 were front disc brake and the master was increased in size to 13/16". A place to start perhaps. Other cars like the 280z/zx and S11 had too large a diameter booster and I doubt it will fit above the steering column and beside clutch master. The first gen S10 200sx might be the same as the B-210/620, don't know, but the 620 is likely the largest master.. Quote Link to comment
BEEBANI Posted January 6, 2009 Report Share Posted January 6, 2009 Mike, the 280zx master will work without the booster. I think Mike Klotz did this on Paula's truck? Quote Link to comment
tyson Posted January 6, 2009 Author Report Share Posted January 6, 2009 yea, I have the single master, so I will be needing to plumb some new lines when I convert to the dual master. Thanks for helping me out, I'm just trying to get the basics in order so I can drive it. I had a 71 521 when I lived in Bellingham Wa. I always had brake problems with that truck, got used to pumping the brakes and planning ahead, I don't want to go that route again. Quote Link to comment
