Archie Posted January 3, 2009 Report Share Posted January 3, 2009 Happy New Year to All!!! I need to replace the u-joints on my 86 1/2 Nissan Hardbody Pick up. No local parts houses can come up with a joint small enough!!:confused: My truck is a 4 cyl, 2 wheel drive, auto trans, extended cab with the 2 piece drive shaft(3 joints). The stock bearing caps are .86 inches in diameter with a 2.08" cross. The dealer wants $35.00 each:eek: Are these joints used in another application, one of the cars maybe , which the other parts houses don't cross reference to?? Also, I need to replace the interior rear view mirror. Do any of the other Nissan models share this mirror so when I go looking on ebay and such, I will have more parts to choose from?? Thanks everyone for the help!!! AL Quote Link to comment
datzenmike Posted January 3, 2009 Report Share Posted January 3, 2009 Try the '84-'86.5 720 U joint. Try the 2 and 4wd. The early D-21 used basically the same motor and rear end on the 720 so they might not have changed them. As for the rear view mirror I use one from a mid '90s Lumina or Monte Carlo. It's the kind that glues directly to the glass and had day/night and two individual map reading lights that can be wired to the door opening. Wrecking yards have them. $30 at the dealer for a $12 part sounds about right. Did you try getting the Nissan part number and taking it to an auto parts store and have them cross reference it? Also the early D-22 Pathfinder is built on the same platform as the Hardbody and shares many of the drive line components. Quote Link to comment
Archie Posted January 6, 2009 Author Report Share Posted January 6, 2009 Thanks Datzenmike:thumbsup: I will try that too. I thought I had them from Autozone, but like most of the chain parts stores, when I got there the parts were wrong.:( Quote Link to comment
yello620 Posted January 6, 2009 Report Share Posted January 6, 2009 my u-joint book list only three part numbers for the datsun/nissan 2wd trucks, and none of them match the dimensional specs that you have listed. spicer #'s 1-0027 2.233 across the joint with caps on and cap diameter is .985 Used one the 69-85 2wd truck 1-0029 2.874 across and 1.103 diameter Used on 86-01 2wd truck 1-0153 2.969 and a 1.063 cap I found two other part numbers that nissan used also 1-0028(66-76 small car) and a 1-0449(4wd from 85.5-01) Good luck Quote Link to comment
