ImInked Posted December 29, 2008 Report Share Posted December 29, 2008 Hey guys, i just bought a '71 521 and the firewall is cracked right behind the gas peddle. needless to say the gas peddle flops around quite a bit and sometimes ends up behind the brake peddle!!! not too safe. would anyone on here want to weld that up for me? welding is not my strong point. nor do i have a welder. i've called all over the place and it seems no one wants to do this. any help?? Quote Link to comment
kennysgreen280z Posted December 29, 2008 Report Share Posted December 29, 2008 Have you called Garage Autohero in woodinville? Quote Link to comment
ImInked Posted December 29, 2008 Author Report Share Posted December 29, 2008 I haven't, but I will. Thanx for the info Quote Link to comment
Jester Posted December 30, 2008 Report Share Posted December 30, 2008 I put a small peice of angle iron on the back side of mine and welded it in. I just shaped it to match the small ledge right were it is spot welded at the factory. Quote Link to comment
ggzilla Posted December 30, 2008 Report Share Posted December 30, 2008 the gas peddle flops around quite a bit and sometimes ends up behind the brake peddleI'm trying to imagine what will happen if you step on the brake in that scenario... Quote Link to comment
endubguy Posted December 30, 2008 Report Share Posted December 30, 2008 my buddy is an awsome welder if garage auto here is too busey i will ask him if you want me to hes in kenmore. it would be super cheep Quote Link to comment
ImInked Posted December 30, 2008 Author Report Share Posted December 30, 2008 I ended up fanning a patch panel for it out of steel. Endubguy, yes, ask your buddy if he could weld my patch in place. Right now I have it bolted down but would like it welded. PM me with his info. Yes, when I drove it home the peddle got stuck under the brake! I don't ever want that to happen again. Quote Link to comment
Guest DatsuNoob Posted December 30, 2008 Report Share Posted December 30, 2008 If your temp fix will work for a little while, drive it down to my place, and I'd be happy to throw a couple beads on it for you. Quote Link to comment
ImInked Posted December 30, 2008 Author Report Share Posted December 30, 2008 Thanx! I'll take you up on that. I'll PM you when I'm ready. I have a few more fires to put out on this truck first, but man I'm havin' fun!! Quote Link to comment
endubguy Posted December 30, 2008 Report Share Posted December 30, 2008 were u still interested in the wheels?? Quote Link to comment
Bleach Posted December 30, 2008 Report Share Posted December 30, 2008 If your temp fix will work for a little while, drive it down to my place, and I'd be happy to throw a couple beads on it for you. Can you install my 350Z suspension into my 280ZX for me? that'll require a little welding, right? :mellow: Quote Link to comment
Guest DatsuNoob Posted December 31, 2008 Report Share Posted December 31, 2008 Lets put it in the Fairlady instead :D Quote Link to comment
