Socalman Posted September 11 Author Report Share Posted September 11 1 hour ago, datzenmike said: Two 55 watt high beams + 110 watts plus two hi/low 50 watt lights = 100 Total 210 watts. On a charging 14v alternator that's just 15 amps. Fine on stock wiring but a 30 amp fuse will over protect by double. The fuse will never blow but stock wiring could over heat if there is a high draw. Same with the starter solenoid wiring. Find the gauge and look up the maximum current carrying capacity and fuse just below that. Not good with stock gauge headlight wiring and ground. I see what you’re saying but the wiring coming into the module is already fused isn’t it? Since it’s in stock form? The wiring coming out of module that is fused with the 30 amp fuse I used 10 gauge wire since the lug was much bigger coming out. So I am thinking I unknowingly wired it up correctly? Quote Link to comment
