Crusty320 Posted August 7 Report Share Posted August 7 I’ve “found” 3 leaks one on top of the gas tank around the fuel sender? I think that’s what they are called here’s a picture of it it’s leaking around the gasket when the tank is full and the gas splashes up. I just cut a new gasket and re-threaded 2 stripped holes, and tightened it down it’s still leaking though. I’m thinking it might be the type of gasket? It’s a rubber fiber sheet I cut it out of. The clutch leak is really slow and I don’t have a lead on yet really, right now I’m thinking it’s the slave but it’s hard to tell cause it I’m also leaking oil and need to Im fix that before I can figure out the clutch. Oil is leaking by the filter I can’t seem to get the right gasket for it.If anyone knows where to get a gasket for that or what kind I need to get that’d be great Quote Link to comment
datzenmike Posted August 7 Report Share Posted August 7 If actually rubber, gas will dissolve it. Probably Nitrile or Viton? should be something petroleum resistant but everyone calls it 'rubber'. Quote Link to comment
Stoffregen Motorsports Posted August 8 Report Share Posted August 8 (edited) I think "buna n" is the right material to use for that job. You can get sheets of it at McMaster Carr - https://www.mcmaster.com/products/rubber/rubber~/oil-resistant-buna-n-rubber-sheets-bars-and-strips/ Even a paper gasket would work, if you had some sealant on it. The threads need some sealant on them. I use Threebond 1211 which used to be sold at any motorcycle shop. Now I just buy it on Amazon. Edited August 8 by Stoffregen Motorsports Quote Link to comment
Crusty320 Posted August 9 Author Report Share Posted August 9 8 hours ago, Stoffregen Motorsports said: I think "buna n" is the right material to use for that job. You can get sheets of it at McMaster Carr - https://www.mcmaster.com/products/rubber/rubber~/oil-resistant-buna-n-rubber-sheets-bars-and-strips/ Even a paper gasket would work, if you had some sealant on it. The threads need some sealant on them. I use Threebond 1211 which used to be sold at any motorcycle shop. Now I just buy it on Amazon. I’ll look into getting some “buna n”. do you know anything on oil filter gaskets or how to set it right. I picked up a wix filter off rock autoand it came with gaskets, they were a tad big so I’m using my old ones it’s still not sealing correctly though https://www.rockauto.com/en/catalog/nissan,1965,320,1.2l+l4,1440392,engine,oil+filter,5340 Quote Link to comment
Stoffregen Motorsports Posted August 9 Report Share Posted August 9 16 hours ago, Crusty320 said: do you know anything on oil filter gaskets or how to set it right. I picked up a wix filter off rock autoand it came with gaskets, they were a tad big so I’m using my old ones it’s still not sealing correctly though Sorry, can't help with that. The issue there is probably more manufacturing related than a materials issue. Quote Link to comment
