Socalman Posted March 22 Report Share Posted March 22 Hey all, I have this matchbox Dizzy, I somehow screwed up the reluctor, luckily I had another dizzy to put in its place, but I want to replace the reluctor and sell it to someone who needs one or save it as a spare. Just wondering if anyone had a lead on where to buy one or if this eBay one would fit? I tried contacting manufacturer Cardone but they don’t deal with the public, said I could get Oreillys or whatever to send it in for a rebuild. Which it doesn’t need. https://www.ebay.com/itm/305432712676?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=VNO7ohSsT9C&sssrc=2047675&ssuid=&widget_ver=artemis&media=COPY Quote Link to comment
Socalman Posted March 22 Author Report Share Posted March 22 Btw, shaft is not bent, reason it broke it’s because I wasn’t paying enough attention when I put it back together. Quote Link to comment
datzenmike Posted March 22 Report Share Posted March 22 Should still work, does it? Quote Link to comment
Socalman Posted March 22 Author Report Share Posted March 22 14 minutes ago, datzenmike said: Should still work, does it? It has a little miss in it. Quote Link to comment
datzenmike Posted March 22 Report Share Posted March 22 Could be a spark plug that's dirty, a bad plug wire, cracked distributor cap or rotor even a crack in the top plastic part of the coil. Quote Link to comment
Socalman Posted March 22 Author Report Share Posted March 22 8 hours ago, datzenmike said: Could be a spark plug that's dirty, a bad plug wire, cracked distributor cap or rotor even a crack in the top plastic part of the coil. True, but it went away when I installed my other Dizzy. It could be in my head, since I know its broken, but it had a little stumble and hesitation...everything the same except dizzy.....could be as simple as maybe it wanted different timing, I could feel the magnetic force on the good one compared to broken one when turning by hand and passing the stator contact points..... Quote Link to comment
