Dannyboii Posted January 7 Report Share Posted January 7 My 210 wagon does not have a driver side seat, so I poorly rigged up a seat from a 300zx that doesn't fit well or sit right. A year later my ass is tired of it, what are my options for fitting a new seat if I do not have a bracket to work off of? I'm located in the southern US so these 210's are very few and far between, I haven't found a seat or bracket in the year I've been looking. And I do have the Cat hump btw, so the courbeau bracket will not fit. Any help is greatly appreciated. (Re-post, No response in 2 days) Quote Link to comment
Duncan Posted January 7 Report Share Posted January 7 Ages ago, I put a set of Miata seats into a Datsun 1200 Coupe. I used the MIata seat rails, but it did require me making some rear spacers out of 2" square tubing to lift the back two mounts to level the seats. I also had to heat and bend the front two mounts downward to use the 1200 seat cross member for mounting. I had to do some some similar fab when I mounted some BMW Series 3 seats into a 510 wagon. I suspect there will not be too many options for something that will bolt in easily. It's a small car, and (unfortunately) most anything you install will need some fab work to fit. 1 Quote Link to comment
Dannyboii Posted January 7 Author Report Share Posted January 7 4 hours ago, Duncan said: Ages ago, I put a set of Miata seats into a Datsun 1200 Coupe. I used the MIata seat rails, but it did require me making some rear spacers out of 2" square tubing to lift the back two mounts to level the seats. I also had to heat and bend the front two mounts downward to use the 1200 seat cross member for mounting. I had to do some some similar fab when I mounted some BMW Series 3 seats into a 510 wagon. I suspect there will not be too many options for something that will bolt in easily. It's a small car, and (unfortunately) most anything you install will need some fab work to fit. That's kinda what I figured. I do have a miata seat for it, But I haven't made the drive to pick it up from my buddy's place since I moved. I suppose I'll start with that. Thanks! Quote Link to comment
