MannyL Posted December 29, 2023 Report Share Posted December 29, 2023 My 1980 720 has 8 bolts on the valve cove and the gasket they gave me only has 6 holes and definitely doesn’t line up? Any help Quote Link to comment
datzenmike Posted December 30, 2023 Report Share Posted December 30, 2023 If it really is an '80 720 then it should have 6 bolts or the engine has been changed. The 1980 model year was the last 720 that came with the two liter L20B engine and it had 6 bolts. Is your carburetor on the right or passenger side of the engine? If yes then you have a Z series engine and it does take 8 bolts to hold the valve cover. I think they still put the build date on the driver's door jam so have a look. If you have a 1980 model year the build date will be between June (1/'79) and July (7/'80) The 1981 model year begins July (8/'80) so possible to have an '81 that was built in 1980. 1 Quote Link to comment
MannyL Posted December 30, 2023 Author Report Share Posted December 30, 2023 Carb is on passenger side it says L20B engine 8 plug unsure of date 1 Quote Link to comment
Fat510 Posted December 30, 2023 Report Share Posted December 30, 2023 L20Bs were 4 plug with carbs on the driver side. They gave you the right one for the year but your truck has the newer style engine. Exchange it for an 81+ 720 gasket. 1 Quote Link to comment
datzenmike Posted December 30, 2023 Report Share Posted December 30, 2023 The tag identifies the engine installed at the factory. If it says L20B then your engine has been swapped in. There were three Z series engines Z20, Z22 and Z24. To know exactly what you have look between the two pair of exhaust outlets just below the #2 and #3 spark plugs on the block. There is a flat raised boss with the engine displacement stamped on it. Quote Link to comment
