CanDat Posted December 28, 2023 Report Share Posted December 28, 2023 Hey, I have a 77 620 project that I’m in the midst of and I would like to know if anyone can take pictures of the brake/fuel line routing and associated insulators/clips as a diagram doesn’t suffice. Quote Link to comment
Shortbed Posted December 29, 2023 Report Share Posted December 29, 2023 If I can figure out how to upload photos I can help you out today. Got a non-cal 77 620 with A/C. Only thing is fuel line around the gas tank/ engine bay area might be slightly different as I have electric fuel pump. Sorry for assuming you have a mech pump. Bleeding air from the lines today so i'll take pics as I go. Might be a minute, taking care of family as well. Quote Link to comment
datzenmike Posted December 29, 2023 Report Share Posted December 29, 2023 If you don't have the old lines to follow then generally all fuel and return line as well as brake lines to the rear, go down the right frame rail about half way up on the inside where they are most protected. In the hydraulic brake system there is a NLSV (Nissan load sensing valve) under the passenger seat. From the gas tank there is a vent line that runs forward and crosses over to the left side at the cross member that anchors the torsion bars under the cab then continues forward against the inside of the left frame rail to the charcoal canister by the radiator. All it has to do is work and not be in the way of anything else. Make it work. Quote Link to comment
CanDat Posted December 29, 2023 Author Report Share Posted December 29, 2023 Ya I understand the general layout and to making it work, I am kind of a visual guy and like referencing pictures and such. That is all. I also, like a dummy, didn’t take pictures prior to disassembly. Quote Link to comment
datzenmike Posted December 29, 2023 Report Share Posted December 29, 2023 5 hours ago, CanDat said: I also, like a dummy, didn’t take pictures prior to disassembly. Welcome. Quote Link to comment
Shortbed Posted December 30, 2023 Report Share Posted December 30, 2023 @CanDat sorry my man, was not able to flush brakes and get under carriage photos. all I have are engine bay. I can upload them tomorrow LMK Quote Link to comment
CanDat Posted December 30, 2023 Author Report Share Posted December 30, 2023 @Shortbed no problem, in fact I found a Haynes manual and it’s very informative/detailed. Quote Link to comment
datzenmike Posted December 30, 2023 Report Share Posted December 30, 2023 The 620 was around for 7 years. Haynes condensed it into 1/2" thick and the '78 and '79 is just a supplement in the back. Only good thing about the 'manual' are the electrical diagrams and that's why I have it. Best thing is a used Nissan FSM (factory service manual) for the '77. Has 1.5" thick of everything and how to take it off, fix/adjust and replace it for that year. All manner of clearances and specifications. Every year had different emissions equipment and electrical components. Hard copy is best so you can read it in the crapper every morning but they are down loadable... https://datsuntrucks.com/wp-content/uploads/2020/03/Service_Manual_Datsun_Pick-Up_1977-1.pdf 1 Quote Link to comment
RustedRails Posted December 31, 2023 Report Share Posted December 31, 2023 (edited) @CanDatDo you still need the pics? I have a bunch when I took the cab and bed off. Edited December 31, 2023 by RustedRails Quote Link to comment
CanDat Posted December 31, 2023 Author Report Share Posted December 31, 2023 Absolutely, the more information the better, thank you. Quote Link to comment
RustedRails Posted January 1 Report Share Posted January 1 (edited) 6 hours ago, CanDat said: Absolutely, the more information the better, thank you. Here you go, this is a few that I have. This is from a 77 kingcab with no AC. Edited January 1 by RustedRails Quote Link to comment
