datzenmike Posted October 12, 2023 Report Share Posted October 12, 2023 Z22 with KA24E head???? The E head has a very large combustion chamber and coupled with a Z22 piston dish of 9.32cc the compression is in the basement @ 7.68. Over bore to 89mm and swap stock KA24E 2.8cc dish pistons in and you have a big bore 2300. KA-E pistons on Z22 rods stop 1.55mm below the deck so milling 1mm off will remove over 6cc of volume from the combustion chamber giving you a compression of 8.26. If you remove the full 1.55mm the compression is 8.6. If there are high compression KA-e pistons you want a dome volume of at least 10cc to get 8.6 and mill the block surface for more. A KA24DE head volume is very close to an L series head so on a Z22 block the compression is 9.59 but there's the sorting out of the timing chain and gears. Quote Link to comment
dew Posted October 12, 2023 Report Share Posted October 12, 2023 Thanks Mike. Probably your umteenth time repeating that, but most concise I’ve ever read. Haven’t had it confirmed but read on old forum that Toyota R series timing (or crank?) pulley makes KA24de head timing match the Z bottom, plus upper part of timing cover? Quote Link to comment
datzenmike Posted October 12, 2023 Report Share Posted October 12, 2023 The KA24E cam sprocket is identical to the L and Z series sprocket.... except that it's a single row chain. Pretty sure a Z or L cam sprocket will fit. Chain length is another matter. Depends if cam on the KA is higher or lower to the block than the Z series. Quote Link to comment
dew Posted October 12, 2023 Report Share Posted October 12, 2023 Just sayin’, all you guys here are an awesome (and patient) resource. Learned SO much on this forum. Perhaps I can find a Canadian/ Mexican/JDM KA20de to play with.... Quote Link to comment
