nissan720 Posted August 27, 2023 Report Share Posted August 27, 2023 this is my first attempt at building ka24 engine .when lining up the timing marks .does it matter if the intake valves are open or closed? looking for verification. thanks for your responses in advance.i do have a chilton manual that i am using along with the haynes maunal Quote Link to comment
datzenmike Posted August 27, 2023 Report Share Posted August 27, 2023 Worst manuals ever. They just copy (and make mistakes) from the official Nissan published factory service manual (FSM). Chiltons and Hainse cover many years generally but not your year specifically. But I digress. KA24E Hopefully the number one valves are both closed and the engine is already at TDC. If not, it is very risky to rotate the cam with a piston at TDC. You can bend a valve doing this. Quote Link to comment
nissan720 Posted August 28, 2023 Author Report Share Posted August 28, 2023 so my first order of business is to make sure the #1 piston is at tdc okay got that part. next order of business is to make sure that i rotate the camshaft to close the #1 intake and exhaust valves before putting on the timing chain? Quote Link to comment
datzenmike Posted August 28, 2023 Report Share Posted August 28, 2023 I would make sure the engine is NOT at TDC if turning the cam. An opening valve could hit a piston top. Was the head off? Are you just replacing the timing chain? need more information Quote Link to comment
nissan720 Posted August 29, 2023 Author Report Share Posted August 29, 2023 no the head was not taken off. replacing time chain tensioner with an adjustable one. the guy who replaced the chain before didn't do a good job.truck won't get over 45mph. thats why i am going to attemt to fix it myself . i am currently waiting on an engine building friend of mine. but thats it waiting on someone else! Quote Link to comment
