Veraciousreasoning Posted August 2, 2023 Report Share Posted August 2, 2023 Hey all, I browsed the search feature but can't find it. Does anyone have a decent step by step guide on installing the weber carb to a 1980? First time installing a carb Also does anyone want a Hitachi carb for a L20b? Quote Link to comment
stuart720 Posted August 15, 2023 Report Share Posted August 15, 2023 Buy a 32/36 kit, make sure you get the correct adapter plate, in your case, for an l20b. Remove and trash that original hunk of shit. Install new in reverse. Carb kit should come with diagram for vacuum lines and tuning. If I remember correctly, the only thing I had to figure out was a mount for throttle return spring, the kit came with a ridiculously long one. Maybe a gasket too.... 1 Quote Link to comment
datzenmike Posted August 15, 2023 Report Share Posted August 15, 2023 Try Google and type: install Weber 32/36 on L20B. Ratsun. The Google search is much better. Be sure to put Ratsun in the search. 1 Quote Link to comment
