Dusten Posted May 3, 2023 Report Share Posted May 3, 2023 Do I need to drill and tap the manifold for the throttle linkage? It looks like it goes here. My current intake has it bolted up in a place that won't exist with the cannon Quote Link to comment
banzai510(hainz) Posted May 3, 2023 Report Share Posted May 3, 2023 (edited) this should fit be honest do you really want to go thru with taking all that apart cause look like you go the other style exhaust manifold????Esp if you have the heated intake from the exhaust manifold. the stove pipe type to heat the intake so in winter the carb dont freeze. If in Calf I wouldnt worry about it This will look cleaner but I highly dought you get even 3 hp out of this https://www.ebay.com/itm/192561536005?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20201210111314%26meid%3Dd1c784fad0ef477897993722885f9b74%26pid%3D101195%26rk%3D8%26rkt%3D12%26sd%3D191689908217%26itm%3D192561536005%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DSimplAMLv11WebTrimmedV3MskuWithLambda85KnnRecallV1V4V6ItemNrtInQueryAndCassiniVisualRankerAndBertRecall%26brand%3DRed+Line&_trksid=p2047675.c101195.m1851&amdata=cksum%3A192561536005d1c784fad0ef477897993722885f9b74|enc%3AAQAIAAABYA2rugFlOq3qu1cLac%2F%2Fk6Vp0Oa0HaJIqoXKeIiOR%2BTUgsSvHaeyPxKYu6UqHqq7GaGyKVqHQnjeiiXcQpMGw2t3aB%2BssGfjtIWOBj8wExc7oYYP7xGMyQCrHDyDaSaWjB1CueI3A94n0yxXX5dx5gAmoO1myfFNUaQg9eCI6VSC2y7myQosf9AR6OcDMhIAWN0DFR3nOhwuAuL%2Borzzzk6pGPH8dNW2%2BDjtwVzaOeXCtjIyJvgQGJvB3ZiouvtxQGavre7IfeE5AyR3pKICkFKangXfSzSuIRyV%2FBLRpoTN0HDaDjW7Ujr2sAup2tUaqrxjTkyfBLi8wIQbtoTd3puR%2FeE%2Fp42U9zLmMTvrRxD%2B3WrrvHwa2zhRQlF75e7hX9RtXQgVp1nTNYR71HSzzSYBWGbyG1%2BVHon6b6iDgawA7ylvxwdcOgJ%2Bo2yQuh0H7J3%2FGKwoQPkifH62D3F3kzU%3D|ampid%3APL_CLK|clp%3A2047675&epid=5020215874 Edited May 3, 2023 by banzai510(hainz) Quote Link to comment
Dusten Posted May 3, 2023 Author Report Share Posted May 3, 2023 Then I'll assume my first question is yes I need to drill and tap. Quote Link to comment
banzai510(hainz) Posted May 3, 2023 Report Share Posted May 3, 2023 (edited) you see the link there is no need to drill and tap just put the bracket over the 2 weber holes and put the nuts on to hold down then fish thru the throttle cable and lock it Edited May 3, 2023 by banzai510(hainz) Quote Link to comment
SupDoc Posted May 4, 2023 Report Share Posted May 4, 2023 Here is a picture of my Cannon (in a 510). No drilling and tapping. Don't know why the picture is upside down... Quote Link to comment
Dusten Posted May 4, 2023 Author Report Share Posted May 4, 2023 Thanks guys. I've got that new bracket on order A lot of my truck is turning out to be more half-assed than thought. So certain simple mods are more work than they should. And I wasn't sure about the drilling because the stock linkage on mine is obviously a hack setup 1 Quote Link to comment
banzai510(hainz) Posted May 4, 2023 Report Share Posted May 4, 2023 be honest your hack set up is not that bad. maybe paint it and it will look ok. But Im not into drilling in tapping if there is a part to fix it Quote Link to comment
Dusten Posted May 4, 2023 Author Report Share Posted May 4, 2023 23 minutes ago, banzai510(hainz) said: be honest your hack set up is not that bad. maybe paint it and it will look ok. But Im not into drilling in tapping if there is a part to fix it It's not my setup thankfully it's inherited. I'll clean it up when I swap manifolds. I ordered that part you linked. But in my eye it bolted to the intake not the carb base. Quote Link to comment
