Lonewolf1990 Posted January 10, 2023 Report Share Posted January 10, 2023 Trying to fix up my wiring to add some aftermarket parts , which color wire is the ignition , so my gauge and etc turn on when I turn on the truck Quote Link to comment
datzenmike Posted January 10, 2023 Report Share Posted January 10, 2023 Not a good idea to connect anything to the ignition switch as it is not running through a fuse... an in line fuse is ok. The Blue wire on the ignition switch has power in the ON and ACCESSORY position and only powers the cigarette lighter. But again it is not fused, you will need an inline fuse if using it. Any of the three fuses on the left side of the fuse box are turned on and off by the ignition switch. 1 Quote Link to comment
