Greaser2 Posted January 8, 2023 Report Share Posted January 8, 2023 Any advice on rebuilding a SSS Manual? Shifts are stiff and load growns. Quote Link to comment
datzenmike Posted January 8, 2023 Report Share Posted January 8, 2023 Check the oil? Aren't the SSS manuals rather rare as almost all were automatic. They appear to be the same as the 510 F4W63 transmission. Quote Link to comment
Greaser2 Posted January 9, 2023 Author Report Share Posted January 9, 2023 (edited) Mike, any way to identify a F4W63? Edited January 9, 2023 by Greaser2 Quote Link to comment
datzenmike Posted January 9, 2023 Report Share Posted January 9, 2023 Has a bolt on removable oil pan on the bottom. Waffle pattern on the main body. One piece front bell housing and main body bolted to the rear tail stock. No adapter plate sandwiched in between. 'A' type shifter outside the transmission at the very rear. Speedometer on left side Quote Link to comment
Greaser2 Posted January 9, 2023 Author Report Share Posted January 9, 2023 I can see the starter is on the passenger side. The R16 411 has starter on driver side. But could be a modified version. Quote Link to comment
datzenmike Posted January 9, 2023 Report Share Posted January 9, 2023 2 hours ago, Greaser2 said: I can see the starter is on the passenger side. The R16 411 has starter on driver side. But could be a modified version. R16 and R20 starters are on the left side. Engine must be something else. Got a picture? Should look like this... Valve cover held on with two fasteners... http://www.zcarblog.com/wp-content/uploads/2020/07/IMG_0044.jpg The F4W63 was used on L, J and Z series engines. It a simple matter of changing where the engine bolt pattern and starter go on the front case. The R16 made about 97 hp which is well within the capability of the F4W63... if it is the F4W63 Quote Link to comment
Greaser2 Posted January 9, 2023 Author Report Share Posted January 9, 2023 Very similar Quote Link to comment
datzenmike Posted January 9, 2023 Report Share Posted January 9, 2023 Damn close. Quote Link to comment
Greaser2 Posted January 9, 2023 Author Report Share Posted January 9, 2023 Have u seen these needle bearings before. Probably 3 sets on the main shaft under each gear. I can’t locate replacements. Just about all other components are available on the roadster sites. Looks to be about 54 needles per. Quote Link to comment
datzenmike Posted January 9, 2023 Report Share Posted January 9, 2023 From front to back.... 32272-14600... also common to the F4W63 in the 521/510/610/710 the 63A 5 speed in B210/S10/A10 and 71B in the Z cars and 620 truck and more... 32616-14600- unique to the 311 32264-14600... also common to the F4W63 in the 521/510/610/710/early 620 the 63A 5 speed in B210/S10/A10 and 71B in the Z cars and 620 truck and more... Quote Link to comment
Greaser2 Posted January 10, 2023 Author Report Share Posted January 10, 2023 Thanks Mike, got them ordered Quote Link to comment
datzenmike Posted January 10, 2023 Report Share Posted January 10, 2023 Always a good idea to confirm part numbers. I'm pretty confident but you shouldn't necessarily be. Quote Link to comment
Greaser2 Posted January 12, 2023 Author Report Share Posted January 12, 2023 Mike, would a pinned shaft trans still have all the same parts as a half moon shaft trans? Is a pinned shaft always have BOrg Warner components? Quote Link to comment
datzenmike Posted January 12, 2023 Report Share Posted January 12, 2023 That shaft with the half moon wear on it is the same shaft for all F4W63 4 speeds. My manuals show some with a hole and a pin for it, some do not. Most early Datsuns used Borg Warner 35 automatics. The April '71 510 was the first use of the 'in house' JATCO 3N71B automatic. I don't think any of the F4W63 are Borg Earner units themselves but they probably use Warner or Warner style synchronizers. I think that is what the W in F4W63 stands for. Quote Link to comment
