710wagon Posted June 21, 2022 Report Share Posted June 21, 2022 Does anybody know if I can just get a standard gas hose and cut it to size to fit? The only thing I don’t know is how it attaches up by the body where the fuel cap is located. they currently will dump fuel when I make a left-hand turn or if I overfill it will come pouring out of there so I know it’s this little rubber piece. any suggestions as to where I can get this unless if it’s just a generic hose from AutoZone and how hard is it to replace? Quote Link to comment
thisismatt Posted June 21, 2022 Report Share Posted June 21, 2022 Stock filler neck is probably a molded rubber sandwiched with the metal ring inside the filler door. Your best bet is to upgrade the whole neck with something more modern, ala: 1 Quote Link to comment
