datzenmike Posted February 12, 2022 Report Share Posted February 12, 2022 You may have inadvertently fixed their blown exhaust coil fuse by wiring the exhaust coil to the intake coil. Running on just the intake plugs completely changes the burn time making it longer. In effect the timing needs to be advanced to about 10 BTDC for single plug. The engine will run poorly as it is still at 5 degrees and will act like the timing is retarded. Quote Link to comment
