JacobBieg Posted December 1, 2021 Report Share Posted December 1, 2021 I'm thinking of swapping out my carb on my A14 but I'm not sure. I'm having some carb problems and I know that switching to something like a new weber would fix that and also gain me some hp, the main problem lies within the airfilter housing. Since my engine got all sorts of crazy valves that lead into the air filter housing would I need to modify the housing in order to fit it on a weber carb? Any ideas? Quote Link to comment
datzenmike Posted December 1, 2021 Report Share Posted December 1, 2021 Yes you would. These are for an L series engine but it's basically the same procedure. The stock air filter allows you to keep the ATC auto temp control and the filter is larger, lasts longer and is 1/3 the price of the Weber filter. 1 Quote Link to comment
JacobBieg Posted December 1, 2021 Author Report Share Posted December 1, 2021 I have the cat non California version which has sensors right next to the hole for the carb, so I don't know if id be able to make the hole much bigger. Am I out of luck? Quote Link to comment
datzenmike Posted December 1, 2021 Report Share Posted December 1, 2021 You may have to make a flat plate and weld/rivet it to the stock filter housing. In that case you can move the 'sensors'. The two 'sensors' are... Hot idle compensator.... Overly hot under hood temperatures cause a rich mixture. This device leaks air into the intake to lean it out. ATC sensor.... (auto temp control) this device senses air temp and bleeds vacuum to the ATC servo motor in the snorkel to maintain a constant air inlet temperature. Quote Link to comment
JacobBieg Posted December 2, 2021 Author Report Share Posted December 2, 2021 Hmm ok ill look into it, any carb suggestions? As much as I would love to throw a 60$ carb in their, ik it wont work so any carbs in the 250-500 range? Quote Link to comment
datzenmike Posted December 2, 2021 Report Share Posted December 2, 2021 A new Weber 32/36 kit with everything needed for the swap is under $300. Quote Link to comment
JacobBieg Posted December 2, 2021 Author Report Share Posted December 2, 2021 Ok, thank you Quote Link to comment
datzenmike Posted December 2, 2021 Report Share Posted December 2, 2021 A really good stock carb will be more and there are a lot of cheaply made knock offs. Be sure to get an original Weber from a reputable dealer like Pierce Manifolds. There are also Weber knock offs too. Quote Link to comment
