Mspencer Posted November 28, 2021 Report Share Posted November 28, 2021 Well not really replacing it, there was no rubber under the wing windows so am installing new ones. on the bottom of the new rubber are 2 rubber posts shown in the photo. They seem higher then i expected, is this normal? also on the under side there is a spot that says "cut out" if i do it, it would expose the painted metal under it. 1970 R1600 Thanks, just some of the questions i have trying to pick up where the PO left off. Quote Link to comment
MikeRL411 Posted November 28, 2021 Report Share Posted November 28, 2021 I suspect the "cut out" area is for the stud on which the wing rotates. Quote Link to comment
