spottedog Posted December 4, 2008 Report Share Posted December 4, 2008 I have a Quote Link to comment
Fredrik Posted May 1, 2009 Report Share Posted May 1, 2009 Don,t know if the H145 of a 1200 (B110) is identical internal :confused: but part number for spacer-drive pinion bearing was 38165-H1000 for the B110 Quote Link to comment
b210in Posted May 1, 2009 Report Share Posted May 1, 2009 i also have a 74 b210 and the rear end was shot. by the time i added all the parts necesssary to fix it and trying to find them was another ordeal, i simply got another rear from a newer b 210. just something to consider. Quote Link to comment
ggzilla Posted May 2, 2009 Report Share Posted May 2, 2009 (edited) Just swap the whole center section "pumpkin" from a 1971-1973 B110 or 1974 B210 in there. It will be cheaper and certainly easier, someone has one for free. The side bearings rarely go bad unless the diff runs low on oil. Backlash spec is 0.0039 to 0.0059 inch. I've heard of people having trouble finding the spacer. Have you tried Nissan? * 38165-H1001 SPACER-DRIVE PINION BEARING $17.00 * 38154-G04xx WASHER-ADJUSTING DRIVE PINION $3.83 USD Where xx = 00 through 17 for different thicknesses Yes, B110 and 1974 B210 center section is identical. You could also swap a 1975-1978 pumpkin they say you need a 2mm spacer between the pumpkin and the housing. All the B210 housings including 1974 have larger outer axle bearings. The procedure for replacing the spacer is very complicated. Be sure to get the factory service manul. Edited May 2, 2009 by ggzilla Quote Link to comment
datzenmike Posted May 2, 2009 Report Share Posted May 2, 2009 FWIW The H-145 was used in the B-210 till Aug. '74. From Sept. '74 the H-150 rear was used. The 38154-G0400 crush washers ggzilla mentions were used in both. Weather an H150 will fit the H-145 axle housing I don't know. The axles were the same pt. no. for both types. Quote Link to comment
