Guest DatsuNoob Posted December 4, 2008 Report Share Posted December 4, 2008 Curious if after I convert to hardbody front suspension components, will I still be using a 620 front sway bar, or will I need a hardbody one? I haven't got all my stuff yet for the swap, I'm still collecting parts for now, but I need to know which one to get. Thanks Quote Link to comment
Bleach Posted December 4, 2008 Report Share Posted December 4, 2008 due to vehicle width, I would guess you need to keep the 620 sway bar. Possibly just drill new holes for the end links in your Hardbody lower control arms. Quote Link to comment
yello620 Posted December 5, 2008 Report Share Posted December 5, 2008 Which Style brake conversion are you doing? Adapters on the king pins or control arm method? Using either method maintains 620 style lower control arms, so the simple answer is you need a stock 620 sway bar. However Bleach mentioned the hardbody lower control arms, i have yet to see a set actually mounted on a 620, yet it looks possible. IF the hardbody lower arm fits then i am not sure on the swaybar. Quote Link to comment
Rubberman Posted December 5, 2008 Report Share Posted December 5, 2008 Do they make a beefier performance type sway bar for the 620? Quote Link to comment
yello620 Posted December 5, 2008 Report Share Posted December 5, 2008 Do they make a beefier performance type sway bar for the 620? Yes, i think that it is made by ADDCO. They make a rear also. Quote Link to comment
Rubberman Posted December 5, 2008 Report Share Posted December 5, 2008 Thanks yello, I'll check them out. Quote Link to comment
