jackfruit Posted June 10, 2021 Report Share Posted June 10, 2021 what screw to adjust the air gap on D4F distributor? it's currently larger than .40. Quote Link to comment
datzenmike Posted June 11, 2021 Report Share Posted June 11, 2021 There were lots of D4F distributors with points and EI. What's this for???? Points are 0.018"-0.022" If an EI distributor, the gap between reluctor and the pick up coil is 0.008" - 0.016" OR 0.2mm - 0.4mm . Loosen the 2 pick up mounting screws and adjust, then tighten them. Quote Link to comment
jackfruit Posted June 11, 2021 Author Report Share Posted June 11, 2021 thanks. B210 EI D4F. I know the gap requirements but was maybe being too ginger with the pickup coil after loosening the screws, as it wasn't moving. http://datsun1200.com/modules/mediawiki/index.php?title=D4F Quote Link to comment
datzenmike Posted June 11, 2021 Report Share Posted June 11, 2021 You could oval the holes to get the adjustment, but shouldn't need to. The distributor part number defines year and application much better than just D4F. It's stamped into the case on the side. Ten numbers beginning 22100-????? Quote Link to comment
jackfruit Posted June 12, 2021 Author Report Share Posted June 12, 2021 21 hours ago, datzenmike said: You could oval the holes to get the adjustment, but shouldn't need to. The distributor part number defines year and application much better than just D4F. It's stamped into the case on the side. Ten numbers beginning 22100-????? 22100-H7680 B-210 A14 '78 Federal, D4F7-01 remote igniter distributor. Quote Link to comment
datzenmike Posted June 12, 2021 Report Share Posted June 12, 2021 Federal emissions 08 '77 and up for '78 model year. Often the distributor can be swapped. Quote Link to comment
jackfruit Posted June 12, 2021 Author Report Share Posted June 12, 2021 (edited) 15 hours ago, datzenmike said: thanks Edited June 12, 2021 by jackfruit Quote Link to comment
