TheMrFlippers Posted January 17, 2021 Report Share Posted January 17, 2021 Went to start the truck to take a short trip, pumped gas, choke set, started just fine. Went to pull out of the driveway and the truck bogged, I couldn’t feather the pedal in anyway to keep it running, and it shut off. Attempted to restart and I’d get the initial fire, but it wouldn’t run. Waited for a few minutes, tried again and got nothing. I finally pulled the lid off the air cleaner and got more air to it and was finally able to feather the pedal enough to get it started. It would run fine for 10 seconds, start bogging badly and I’d have to feather the pedal to get it to stay running. I drove it around the block, floored it a few times from 1st-3rd and noticed if I gave it gas too fast it’d fall on its face and jerk badly. I’d have to let off and slowly press on the accelerator to keep it going. Once I got it back in the driveway it ran for maybe 30 seconds, bogged again and died. This is a rebuilt carb, so I’m unsure where the idle mixture screw is set, but it certainly smells rich, and definitely backfires more than I’m used to. It also backfires if I rev it freely to 3-4K rpms. Thanks for any help. 1 Quote Link to comment
datzenmike Posted January 17, 2021 Report Share Posted January 17, 2021 Did you rebuild it? Does it have a round 6 wire connection at the rear? 1 Quote Link to comment
TheMrFlippers Posted January 17, 2021 Author Report Share Posted January 17, 2021 I didn’t personally rebuild it, a carb shop did. However I popped the hood to check out the plug, did not notice a 6 wire but I did smell copious amounts of fuel, (hasn’t run for over a week) and saw that it was draining out of a vacuum line connected from the a 2 port metal piece on the intake manifold to a valve on the passenger fender well. Let me upload pics. 1 Quote Link to comment
TheMrFlippers Posted January 17, 2021 Author Report Share Posted January 17, 2021 Vacuum port, and residue is in the third and fourth pictures 1 Quote Link to comment
datzenmike Posted January 18, 2021 Report Share Posted January 18, 2021 Not seeing any gas or residue. 3rd picture, what does the large hose connect to? The bottom picture follow the hose, should find it's way back to the intake vacuum. 1 Quote Link to comment
TheMrFlippers Posted January 18, 2021 Author Report Share Posted January 18, 2021 The bottom picture hose goes to that metal port in the third picture. It’s right to the left of the big hose. The big hose goes to some sort of valve. It’s only disconnected because I pulled up the air cleaner to take a picture. In the last picture (with all the hair stuck to it) that’s fuel residue that has come out of the connected vacuum hose. Only thing I could think of to keep such a strong fuel smell (after a week) is float adjustment. But being rather ignorant of carbs, I’m not quite sure. 1 Quote Link to comment
datzenmike Posted January 18, 2021 Report Share Posted January 18, 2021 The bottom hose has vacuum on it when engine running. That just cat hair from climbing in beside warm engine. Next time the engine warms up take the top off the air filter and look at the choke. After 10 min running it should be vertical or fully open, check this. THIS NOT THIS or even partly closed 1 Quote Link to comment
TheMrFlippers Posted January 18, 2021 Author Report Share Posted January 18, 2021 Checked the choke last time it was running, it was fully open. Even double checked and fired it up again it just to make sure it wasn’t a coincidence, didn’t change. I should note, I pulled that hose off and fuel came out, sorry if I wasn‘t clear. 1 Quote Link to comment
datzenmike Posted January 18, 2021 Report Share Posted January 18, 2021 Maybe connected up incorrectly. Could be condensation? All I have is the '84 layout... 3rd picture is likely the boost control valve at top 1 Quote Link to comment
