rwbakk Posted November 18, 2020 Report Share Posted November 18, 2020 Anyone know of a front crank seal that is still avalible? I have checked the nissan numbers in an older post and no one has them. Also tried to find the Victor Reinz FS3597 conplete gasket set that also was listed and came up empty. Quote Link to comment
mrbigtanker Posted November 18, 2020 Report Share Posted November 18, 2020 http://datnissparts.com 1 Quote Link to comment
mainer311 Posted November 18, 2020 Report Share Posted November 18, 2020 (edited) Carpartsmanual lists it as a 13042-B3000, which seems to be available from here: https://www.nissanpartsdeal.com/parts/nissan-seal-oil~13042-b3000.html Nissan parts deal, says that seal was superseded by "A3042-B3000," which is the same price. Some trucks came with a felt ring instead of a rubber seal, in which case the timing cover needs to be modified to be able to fit the rubber seal. Here's some more information: Edited November 18, 2020 by mainer311 1 Quote Link to comment
datzenmike Posted November 18, 2020 Report Share Posted November 18, 2020 The early J13 used a felt ring 13042-3000. This may be why you can't find them. Later ones were probably an upgrade 13042-B3000 1 Quote Link to comment
