Master Cylinders
Pridey71
Hi all,
So I had an issue with the brake and clutch master cylinders loosing fluid (leaking). Thought maybe a pin hole in the clutch line and also a brake line but seemed unlikely for both masters at the same time.
After some investigation I found they were leaking through the back into the cab of the vehicle down the fire wall.
I found some replacements on Aussie E-bay from an Aussie company named Protex.
Both masters cost me $200AUD including postage.
Fitted up perfectly and bled easily after bench bleeding. Now no leaks and the brake pedal feels spot on. Clutch also has good pedal feel.
  • Replies 1
