alexg89 Posted February 21, 2020 Report Share Posted February 21, 2020 ive been on this for about 3 weeks trying to help my buddy. VG30 out of a 95 hardbody.. 2wd . issue is we dont think its the stock motor. .There was an A a B and a W series VG. They all had their differences. The issue we have is that the oil pump was broke when we tried getting the timing gear off the crank.. Order a new pump and the ID of the pump is to small to fit over the drive for the crank. Here are some pictures. I have searched the entire WWW tring to find out where to get this pump and im am stumped. does anyone have any oil pumps laying around that they can take pictures of and measurements .. I have tracked down the pump to 94 and 95 pickups and 93 maximas with the DOHC motor but the pump is not available . Found one that looked like it was it. ordered it and it was wrong. Need help here .. Where are my VG guys at Quote Link to comment
Crashtd420 Posted February 22, 2020 Report Share Posted February 22, 2020 (edited) Take a look at a first gen nissan quest.... more specifically the 96-98 They call it a v40.... Edited February 22, 2020 by Crashtd420 Quote Link to comment
Crashtd420 Posted February 22, 2020 Report Share Posted February 22, 2020 https://www.gumtree.co.za/a-car-replacement-parts/sandton/nissan-hardbody-vg30-vg33-oil-pump-big-hole-second-hand-for-sale/1004277052880910869861809 This is probably what your looking for... Haven't quite figured out what vehicle to reference to find it.... Quote Link to comment
Crashtd420 Posted February 22, 2020 Report Share Posted February 22, 2020 I did find this oem part number, but discontinued.... nissan part 15010-75P01 One confusing thing was your measurement, seems big... this says they refer to them as either 25 or 32mm.... Quote Link to comment
Crashtd420 Posted February 22, 2020 Report Share Posted February 22, 2020 (edited) Not sure how the vg33 oil pump would work.... has that extra tube or something.... even looking up the vg30 quest it shows that tube.... Oh and the nissan part number listed the 95 hardbody... so the motor could be original... Hope some of this helps.... I was bored.... and I miss my old vg30 pathfinder..... sent a rod through the side of that motor... oops... Edited February 22, 2020 by Crashtd420 Quote Link to comment
Crashtd420 Posted February 22, 2020 Report Share Posted February 22, 2020 Never mind about the measurement comment.... forgot about the pulley... Quote Link to comment
Crashtd420 Posted February 22, 2020 Report Share Posted February 22, 2020 It think I found it for you.... https://www.ebay.com/itm/232725928080 Quote Link to comment
alexg89 Posted February 22, 2020 Author Report Share Posted February 22, 2020 That actually is the pump we bought and it's not correct . They sent us the same pump I have pictured . I got with nissan and these ere the pump numbers I found but cant find info on them 15010-12g01 12g02 75p00 75p01 15010-10v01 this is for a 93 maxima dohc but it's supposed to be the correct pump Quote Link to comment
Crashtd420 Posted February 22, 2020 Report Share Posted February 22, 2020 I am confused... the one I listed from ebay does not look the same to me... Can you post a pic of the entire oil pump? The original from the motor and the one you bought? The part number you bought? If you look at the pic of the ebay one it is different from what you bought..... This is the listing from rock auto.... This looks like the one you bought... This is the itm .... You can see the difference how close the machined face is to the outer area... Quote Link to comment
Crashtd420 Posted February 22, 2020 Report Share Posted February 22, 2020 1 hour ago, alexg89 said: That actually is the pump we bought and it's not correct . They sent us the same pump I have pictured . I got with nissan and these ere the pump numbers I found but cant find info on them 15010-12g01 12g02 75p00 75p01 15010-10v01 this is for a 93 maxima dohc but it's supposed to be the correct pump Also from what I'm seeing they vg30 didnt get the larger crank snout till about 95-96... the pump you listed only crosses only up to a 94 pickup.... The oem part number I mentioned specifically says 95 , and 32mm crank... 1 Quote Link to comment
alexg89 Posted February 24, 2020 Author Report Share Posted February 24, 2020 On 2/22/2020 at 9:35 AM, Crashtd420 said: Also from what I'm seeing they vg30 didnt get the larger crank snout till about 95-96... the pump you listed only crosses only up to a 94 pickup.... The oem part number I mentioned specifically says 95 , and 32mm crank... Im cant believe what im seeing lol how did you find this so fast lol im gonna have to do some serious hunting for that pump Quote Link to comment
Crashtd420 Posted February 24, 2020 Report Share Posted February 24, 2020 55 minutes ago, alexg89 said: Im cant believe what im seeing lol how did you find this so fast lol im gonna have to do some serious hunting for that pump I still believe that itm pump I posted looks correct..... What was the part number you ordered? As far as find things.... I have wierd ways I search for stuff.... I do it kind of backwards and sometimes I start with the picture... usually if I can find it visually I can reverse search and find some info..... Although I can't seem to verify that the itm pump I believe to be correct actually fits the 32mm crank.... Quote Link to comment
alexg89 Posted February 24, 2020 Author Report Share Posted February 24, 2020 This is the pump we bought. .based on part number and picture.. and what they sent was not correct Quote Link to comment
Crashtd420 Posted February 24, 2020 Report Share Posted February 24, 2020 2 hours ago, alexg89 said: This is the pump we bought. .based on part number and picture.. and what they sent was not correct Well that sucks..... I hate when they do that.... By the picture it should be the right one.... Any future purchase attempt I would definitely email to make sure you get one that fits a 32mm crank snout.... Quote Link to comment
alexg89 Posted February 24, 2020 Author Report Share Posted February 24, 2020 yah for real.. its probably just gonna come down to sourcing another motor to be honest. .which sucks but gotta do what you gotta do Quote Link to comment
Crashtd420 Posted February 24, 2020 Report Share Posted February 24, 2020 Have you looked into the vg33 oil pumps... They supposedly have the 32 mm crank, but the oil pump is slightly different.. From what I read it seems like the vg33 is a very similar block.... Quote Link to comment
alexg89 Posted February 24, 2020 Author Report Share Posted February 24, 2020 SOOOOO thats what we are doing is using a vg33.. but the way the turbo set up is we cant use the vg33 pump.. thats why we need the stock vg30 pump without the filter housing and so forth .. its a PITA Quote Link to comment
Crashtd420 Posted February 24, 2020 Report Share Posted February 24, 2020 That makes some sense..... One of the things I read was .... actually let me just post the info..... but it sounds like they npt tapped a location on the pump and ran a relocation kit for the oil filter..... is that the part of the vg33 oil pump that's in the way? https://forums.nicoclub.com/true-differences-vg30-vs-vg33-t337554.html Maybe this will help or spawn an idea for you..... I would be inclined to try to make the vg33 pump fit and work... the one your searching for seems to be fairly non existent.... then what if he ever need another one..... Quote Link to comment
alexg89 Posted February 24, 2020 Author Report Share Posted February 24, 2020 Yah thats what i have been trying to convince him of but he dosnt want to fab anything.. well see what happens i guess 1 Quote Link to comment
