510revisited Posted December 21, 2019 Report Share Posted December 21, 2019 (edited) Well, it's been a battle. And even after fighting my go pro and losing, here it is. Quite possibly the first 510 with a "bolt on" holley sniper efi 2300 2 bbl. And a bluetooth controlled distributor. I wanna thank EVERYONE who has chimed in to help me with this struggle. But finally after almost 6 months, here she is running. Needs to be tuned, warmed up to temp to see that everything works. Already spotted a coolant leak at the temp sensor. No biggie. Needs to be wired properly now, and needs throttle linkage. But shes alive!!!!!!!!!! Edited December 21, 2019 by 510revisited 2 Quote Link to comment
datzenmike Posted December 22, 2019 Report Share Posted December 22, 2019 So what was the problem??? Quote Link to comment
510revisited Posted December 22, 2019 Author Report Share Posted December 22, 2019 (edited) 38 minutes ago, datzenmike said: So what was the problem??? To be honest, I added crimped ends onto the wiring, bolted that down right. Ran a ground wire from the dizzy body to the battery. New battery, cleaned plugs, which were pretty wet.. and just messed with the throttle while I cranked it. I was so bummed cause I've been at it all day. I didn't have the gopro running when it first fired. It really surprised me.. Edited December 22, 2019 by 510revisited Quote Link to comment
datzenmike Posted December 22, 2019 Report Share Posted December 22, 2019 Yes. What was the problem? 1 Quote Link to comment
510revisited Posted December 22, 2019 Author Report Share Posted December 22, 2019 (edited) Problem I'm having now is my voltage is way up at 15 ish volts. Not sure why? Internal regulated alt Edited December 22, 2019 by 510revisited Quote Link to comment
