720Ryder Posted October 19, 2019 Report Share Posted October 19, 2019 Passenger side stays on in the front and rear, driver side blinks fine, hazards work perfectly. Anybody know what the most common issue with this could be? Quote Link to comment
datzenmike Posted October 19, 2019 Report Share Posted October 19, 2019 The fact that the 4 way flasher works proves that the wiring and bulbs are OK and should work with the turn signal. In other words a bulb is not burned out or wired incorrectly and the ground is OK. Get an aerosol can of contact cleaner and split the plastic 'clam shell' around the steering column and give the turn signal switch a good cleaning while working the switch on and off to the right. I can't think of anything else it might be. The contact grease does collect dirt and it does dry out. Quote Link to comment
