Fuel sending unit option?
derekg
Looks like mine has bitten the dust (1966 P411 J13). Wiring and gauge (and voltage reg) are fine as a short between the black and yellow wires runs the gauge to past full. Any idea of there are compatible replacements from other cars? I'm not seeing any 411 models on my searched.
Thanks, Derek
  • Replies 3
Do you have yours out?
If you do ,,,,, look at the 65-67 roadster units in the link i post.. Looks like if you straightened the float arm ( looks to me like roadsters is bent) if might be almost exact same thing..  I can't verify if it would or not as i have never tried .. Might wanna start by buying a gasket first to see if mounting holes are same just to be sure.
https://www.datsunparts.com/Fuel-Systems
partnumber: 1365
