wiring a 720 kill switch?
My truck was stolen here in Oakland yesterday.  Luckily I was able to find it abandoned by this homeless encampment not far away.  I have surveillance footage of the guy getting in and starting up my car which only seemed to take a few minutes.  I've been trying to figure out which connection would be best to wire a kill switch into.  Specifically what color wires where and where they lead too.  Any advice is appreciated, thanks!
Nick
  • Replies 6
Electric fuel pump. A full carb will only get you a couple of blocks. The fuel pump relay is beside the glove box, forward of the door hinge just above the kick panel.
https://axleaddict.com/auto-repair/The-Datsun-and-Nissan-Pickup-Fuel-Pump-Relay-What-the-Haynes-Automotive-Repair-Manual-Wont-Tell-You
Looks like the White/Black wire needs a switch in line.
No amount of jumper (hot) wires to the coil or ignition will get her going without fuel. They'll never figure this out. Hide the switch well.
if anyone gets bored and feels like private messaging a good hiding place for a switch i'd be very grateful to hear your ideas.  I'm trying the ashtray right now and although the back corner isn't really visible to the driver but it seems a bit obvious
See if you can find one with a rear defogger switch. My 710 has a small rectangular panel with rocker switch and a blue light to show it's on. Pretty sure it just pushes into the hole in the dash. My B-210 had the same thing.
'80-'81 720
25350-W1000a__63998.1525049952.500.750.J
Mine's like this one...
  • Like 3
Guest Mojo510
In my brothers 84 kingcab we gutted the cig lighter and put a push button switch inside, you could either pull out the lighter and push button or just push the lighter, did this in 1992 for him and still working today B)
S
