720s Posted May 12, 2017 Report Share Posted May 12, 2017 im finally deciding on changing my camshaft to something better I wanted to purchase a camshaft that sounds just like the video link I left I was given the part number which is 99996-D1017 but I can't find it does anyone know where I can purchase this exact camshaft? can someone help me please https://m.youtube.com/watch?v=BJ8ZirXltoM Quote Link to comment
Digi7al Trauma Posted May 12, 2017 Report Share Posted May 12, 2017 Its a nismo cam that i ordered directly from my Nissan dealer. Part number is 99996-D1017. Weird thing is...my Nissan dealer couldn't look up the parts. I had to call Nismo North America to get the part numbersFirst, your question has allready been answered in the comments of the video you linked... and in the sentence you got the part number from, no less^^^^^Also comp cams does sell cams for this motor as well. Secondly... want to point out that you want a camshaft that sounds like this.... are you going to run the same exhaust, manifold/header?I know you aren't planning on running the same carb as the weber 38 outlaw on the truck in the video. So ill just say, your truck may sound far different than this one even if you happen to use the same parts. Mine is not to judge, but there will be more work than just swapping cams... id suggest you read about the nissan anti performance z24 engine to see if this is really worth it for you. Here is a freebie search to get you started http://community.ratsun.net/topic/12503-z24i-infoperformance/ http://community.ratsun.net/topic/71102-napz-engine/?do=findComment&comment=1449195 1 Quote Link to comment
datzenmike Posted May 13, 2017 Report Share Posted May 13, 2017 Cheaper to get a turbo muffler if it's sound you want. BTW no cam and carb swap starts on half a turn and idles perfectly. This was not the first start up. Quote Link to comment
