82 720 4x4 suspension help
82TXDATSUN4X4
Hey guys, anyone know if OME 4x4 Hardbody springs will fit under an 82 4x4? my truck needs some suspension love.... what about the shocks? are those a simple swap? After some research it looks like the D21 4x4 springs a just a little shorter than the 720 4x4 spring. would that mess with my shackle angle?
e522b68e6546c6d740a74b518ae4dfeb.image.3
D21: A. 22 1/8, B. 25 1/8
720: A. 23 1/4, B. 25
the OME springs add 1inch of lift.
also does these springs come as a pair? or do you need to order a quantity of 2 in the checkout?
http://store.arbusa.com/Old-Man-Emu-Leaf-Spring-CS030R-P20976.aspx
  • Replies 4
First, both springs are the same length as per the SFMs. 1,200mm or 47.28"
That said, those two measurements provided, do not add up to the same lengths.
D-21 is 48.25" or 1,225mm
720.. is 47.25" or 1,200.15mm This one agrees with the 720 FSM
Well the differential would appear to be almost an inch closer to the transfer case. The slip shaft on the rear driveshaft should accommodate this.
