simon.dscustoms Posted November 11, 2016 Report Share Posted November 11, 2016 I would like to be able to identify witch A series engine i am looking in pictures by what stock components it has. Also would like to know the difference between said engines. More specifically GX to non GX a14s Quote Link to comment
Morrisun Posted November 11, 2016 Report Share Posted November 11, 2016 Well all that seems simple enough, only it's NOT! Here is a very good place to start, complete with circles and arrows and a paragraph about of some, most times, all of the engines may require:http://datsun1200.com/modules/mediawiki/index.php?title=Category:Engine_Mechanical It's a good read. Cylinder Heads:http://datsun1200.com/modules/mediawiki/index.php?title=Cylinder_Head_Identification Quote Link to comment
datzenmike Posted November 11, 2016 Report Share Posted November 11, 2016 No reliable way as there are so many things that could have been swapped. Best look for the engine ID stamped into the top of the block A 15 A 14 or stamped below the number 4 plug. A 12 also below the number 4 plug Only the coupe had a 63A 5 speed available from December or April '76. The GX is just dress up badges only on coupe models from August '77 on and included a 5 speed emblem. All GX cars were standard A14 engines same as used on the sedans.. 1 Quote Link to comment
Morrisun Posted November 11, 2016 Report Share Posted November 11, 2016 The A14 performance engine is refer to as a A14T. Here's a link to that particular engine: http://datsun1200.com/modules/mediawiki/index.php?title=Hitachi_Twin_Carb#A14T_Engine A simple visual tip-off is dual valve springs and dual carbs. Quote Link to comment
simon.dscustoms Posted November 11, 2016 Author Report Share Posted November 11, 2016 Cool and thanks i have read some of these and they are very helpful. So i have the dogleg 5 speed but it was swapped onto my car before i got so i guess now im wondering if it is the same as the one on my previous 78GX or the lesser 60 series IOW not the 63. Quote Link to comment
simon.dscustoms Posted November 11, 2016 Author Report Share Posted November 11, 2016 Also does anyone want to buy this hunk o junk its a 76 or 74 with 9 millon miles but od only reads 42000 I'll take $20 and a kick in the nards. ...... LoL JK i couldnt resist HAHA.... No but for real this stuff is confusing Quote Link to comment
datzenmike Posted November 11, 2016 Report Share Posted November 11, 2016 Don't think the A14T was ever an option here. So if looking, try Japan or maybe Australia. Cheaper to buy an after market intake and carbs. 5 Speeds for A series 63A only used on the B-210 coupe after '76. Take a look on the tail half of the transmission on the right or passenger side near the reverse lamp switch, to the rear of the adapter plate. There were two 60 series An early '79 dogleg shift and a late '79-'82 regular shift pattern. Look on front of case forward of the adapter plate. Quote Link to comment
simon.dscustoms Posted November 17, 2016 Author Report Share Posted November 17, 2016 Quote Link to comment
