Lug Nut help 1997 -- Nisan Pickup Mag
I have been looking for the correct lug nuts for the Mags wheels off a 1997 Nissan pickup. Part #403001S700 replaced by 560-62340 14"X6" with 6X5.5 bolt pattern and 100MM hub.  It hard to see in the picture but the hole is concaved at the top. There is a steel insert pressed in the Mag and it looks like there should be maybe a special lug nut with a washer could be used. Maybe not. Maybe just a regular threaded through nut with a cover ?
The Nissan and Toyota lugs with washer do not work, the shank is to long.
I found a picture of a shorter shanked lug which I posted below but I cant find a part number or find it available anywhere.
Below I show a picture of a bulge lug I  found but I believe it is definitely the wrong angle for the hole.
I've looked al over and can't find a part number for the lug nuts. All I find is acorn nuts. Not sure if they are the right angle for the lug hole and they would leave the steel ring showing the outside of the hole.
Photo with what looks like special lugs.
Photo of Mag Wheel open holes.
Any help would be appreciated.
  • Replies 2
