bmacster Posted June 28, 2016 Report Share Posted June 28, 2016 I decided to continue onwards with the truck project instead of selling it. Since the last update, I've put on about 10k miles on the beast and she is still going fairly strong. She was sadly stored outside in the winter for 3 months during a move and the cab was full of water from both sides. There are still the remaining issues from before - Fenders needs to come off to clear the water passages Front passenger CV boot ripped on an outing last week Passenger door still needs to be replaced Floor boards needs to be replaced badly Interior needs to be put back together and finished (car Windshield needs to be replaced Fuel pump and relay needs to be connected again Need to get a Weber carb Also need to get new tires ...and new steering box so I can get an alignment... Motor and transmission will eventually need to be pulled and replace the oil pan gasket and most likely the rear main seal. Can't figure out where the rest of the leak is coming from. Front and rear differentials also leaking from the seals Mostly little things that will take time due to my work schedule. Pictures and such to come! Where would be a good place to get some of the items above? Rockauto didn't have most of what I need anymore. Thanks again! 1 Quote Link to comment
Draker Posted June 28, 2016 Report Share Posted June 28, 2016 Post an ad in the classifieds and you should be able to find most of that stuff. 1 Quote Link to comment
bmacster Posted June 28, 2016 Author Report Share Posted June 28, 2016 Post an ad in the classifieds and you should be able to find most of that stuff. Right on, thanks! 1 Quote Link to comment
racerx Posted June 28, 2016 Report Share Posted June 28, 2016 There was a guy selling a 32/36 weber not too long ago. Have you checked the classifieds? 1 Quote Link to comment
