510 (SR20DET) Idle problem
Zac510
Hey guys (finally fixed the electrical issues with the 510)
Would anybody happen to have any ideas as to why my 510(SR20DET) idles fine with the aircleaner disconnected from the ECU. The minute its reconnected it idles horribly and stalls 9 times out of 10. Thought comes to mind that it could have a bad earth/ground.
If the battery is disconnected while the aircleaner is disconnected from the ECU, it will keep running
If the battery is disconnected while the aircleaner is connected to the ECU, it was stall 9 out of 10 times.
Cheers guys, ill try to get a video up shortly showing the problem that im having.
  • Replies 2
