khargis Posted February 17, 2016 Report Share Posted February 17, 2016 Hey y'all. Totally made a bonehead move and accidentally put brake fluid in my power steering. It has been in there for about 5 days. I drained the power steering reservoir, but what should I do next. How bad of a f#@$ up is this? Does anyone have any suggestions? Thank you, Kris 1985 720 2.4 1 Quote Link to comment
flatcat19 Posted February 17, 2016 Report Share Posted February 17, 2016 Remove your return hose and run car to get that fluid out. Add proper fluid to push the brake fluid out. Brake fluid is nasty stuff and will eat at your rubber seals. 3 Quote Link to comment
datzenmike Posted February 17, 2016 Report Share Posted February 17, 2016 I thought all brake seals and flex hoses were rubber and why brake fluid is not a petroleum base product. Either way just flush out with lots of PS or Dexron ATF. If the pump runs dry, raise the front wheels off the ground, start engine and turn lock to lock and shut off. Top up if needed. Start and turn lock to lock and shut off. Check level and add if needed. It object is to use the engine and pump as little as possible to prevent excessive foaming but at the same time push all the foam and air back out into the reservoir. If there is severe foaming, just let sit overnight. When finished you should have your power steering hydraulics back and the reservoir filled to the warm line. 2 Quote Link to comment
flatcat19 Posted February 17, 2016 Report Share Posted February 17, 2016 Put a rubber o-ring in a cup of brake fluid. Watch what happens to it. 3 Quote Link to comment
khargis Posted February 18, 2016 Author Report Share Posted February 18, 2016 Thank you for the feedback. I have a couple questions, but first I have drained the reservoir and also used a turkey baster to get residual fluid out. I have added PS and drained and basted reservoir again. Is the return hose the one that is coming out of the reservoir? When I run engine, should I have that disconnected from the rigid steel tubing that runs along underneath to the drivers side power steering unit? Also, when you say start engine and turn lock to lock and shut off - what is turn lock to lock? How will I know if the pump runs dry? Sorry for all the questions and hope you can have some mercy! Thank you in advance. Kris Either way just flush out with lots of PS or Dexron ATF. If the pump runs dry, raise the front wheels off the ground, start engine and turn lock to lock and shut off. Top up if needed. Start and turn lock to lock and shut off. Check level and add if needed. It object is to use the engine and pump as little as possible to prevent excessive foaming but at the same time push all the foam and air back out into the reservoir. If there is severe foaming, just let sit overnight. When finished you should have your power steering hydraulics back and the reservoir filled to the warm line. 1 Quote Link to comment
datzenmike Posted February 18, 2016 Report Share Posted February 18, 2016 I must strongly disagree. I can't find anything to support DOT fluid dissolving or not being compatible with rubber. Many people call lots of stuff 'rubber'. Such as Viton, Neoprene, Urethane silicon and so on. I mean rubber the shit that grows on trees or the synthetic ... whatever tires and seals are made of. Rubber will dissolve in petroleum products for sure. 1 Quote Link to comment
flatcat19 Posted February 18, 2016 Report Share Posted February 18, 2016 So he should keep the brake fluid in there then? 1 Quote Link to comment
datzenmike Posted February 18, 2016 Report Share Posted February 18, 2016 Of course not. ATF or PS fluid it just that, and DOT brake fluid is brake fluid. Both are different... I was saying that it shouldn't affect anything like the 'rubber' seals any more than if you had dumped water in by mistake. Just flush it out, refill and bleed the system. 2 Quote Link to comment
