andresjcortez Posted October 27, 2015 Report Share Posted October 27, 2015 So I have a datsun 310 fwd with an e15 in it and the engine is busted so a buddy of mine is selling me a ca20e fwd so would I be able to swap that? Quote Link to comment
flatcat19 Posted October 28, 2015 Report Share Posted October 28, 2015 You're new. Hi. Quote Link to comment
hobospyder Posted October 28, 2015 Report Share Posted October 28, 2015 hello, sorry i don't have an answer for you, don't even think i've ever seen a 310 actually. pictures please? Quote Link to comment
datzenmike Posted October 28, 2015 Report Share Posted October 28, 2015 So I have a datsun 310 fwd with an e15 in it and the engine is busted so a buddy of mine is selling me a ca20e fwd so would I be able to swap that? I doubt the E15 and the CA20 share the same transmission bolt pattern. (maybe?) I'm saying I doubt it will bolt to your transmission. I would start by finding out for sure first. If that isn't possible it might be possible to swap the CA20 and it's FWD transmission into your 310. You realize the CA20E is EFI and this will require a high pressure fuel pump and wiring in all the sensors and an ECU into your N10? Quote Link to comment
andresjcortez Posted October 28, 2015 Author Report Share Posted October 28, 2015 the ca20e comes with the original tranny. Could you explain what you mean by wiring all the sensors and an ECU to the n10? (New with cars) Quote Link to comment
datzenmike Posted October 29, 2015 Report Share Posted October 29, 2015 Your car right now is just a simple carburetor. It mixes gas with air mechanically. The CA20E is electronic fuel injection (EFI) There is no carb but the mixing of gas and air is worked out by a computer using sensor inputs. Quote Link to comment
johnzracer Posted December 4, 2015 Report Share Posted December 4, 2015 I looked at that swap for my racecar and decided It was a bit to wide to fit in engine bay. Mongo Quote Link to comment
dat521gatherer Posted December 13, 2015 Report Share Posted December 13, 2015 I can't see the pics.... Quote Link to comment
