Please Help, which front wheel hubs will fit 620
Ranger
Took a look at front wheel hubs today, they are extremely warped on drivers side. I'm looking to replace both sides, are there any hubs compatible with my '74 620. I can't find any replacement part number, I could find a 620 hub from a disc brake type, or a 720 hub easily. Please help!
  • Replies 3
I'd hold off for now and do everything when converting. As to the hub... they don't warp so if the tire is wobbling the rim may be bent or the tire damaged, lug nuts loose, some foreign material between the rim and the hub surface or a worn suspension part like the king pins...
What hubs fit? the '72.5 through '77 620 hubs. I'd make sure it's the hubs first...
