nissan720 Posted October 5, 2015 Report Share Posted October 5, 2015 i have a 84 720 with dual coils.the wires are blue/white and brown.the other coil wire colors are red/blue stripe .which coil is the intake? Quote Link to comment
datzenmike Posted October 5, 2015 Report Share Posted October 5, 2015 Well it really does not matter, as both coils fire together so you can swap the leads or wires around and it has zero effect on starting and running. But if you want them exactly, pull the first fuse on the left side of the fuse box. The coil that stops working is the exhaust side. I would guess that the Blue/White is the negative side of the intake coil and the Brown the positive side of the intake coil. Quote Link to comment
nissan720 Posted October 5, 2015 Author Report Share Posted October 5, 2015 ok thank you Quote Link to comment
