jacimo98 Posted September 7, 2015 Report Share Posted September 7, 2015 Hi guys, first off I hate starting new topics. it seems like I put it in the wrong place all the time.. for that I am sorry. still learning.. anyhow I got a quick question about the pins in the bell cranks. that are connected to the frame on the parking brake system. one of them is closer to the drivers side, and one is in the center. (this one cantilevers the threaded rod going thru the cross member.) anyhow my son is doing a frame off. minus the body work. for his senior project, and we got hung up here. we pulled the cotter pins, expecting the pins to pull right up and out...not so much.we tried penetrating oil, heat, and a pretty good size ball peen! neither one of them want to move very far..we decided to stop and ask. instead of going all jiffy lube on it! any input would be appreciated..thanks. 1 Quote Link to comment
DanielC Posted September 8, 2015 Report Share Posted September 8, 2015 All the body parts on a 521 are sized in inches. You can probably find the right size clevis pins at almost any hardware, or farm sumpply store. And new cotter pins to hold them in the same aisle. 1 Quote Link to comment
